Hopefully they will help you in good faith. I have been running my Watanabes (72ID)without hub ring locators, the only thing they do Is take the load off the stubs but they should work without them(I have done a Gymkhana with them like this). I usually would buy some for my wheels but after buying bits for my suspension Im a bit strapped for cash.
In sky high news, I fitted my rear springs. On the way to get the perches turned down I went along Lonely track with my old springs and smashed so hard my head hit the roof(3Kg). Once I fitted the new springs I went back along the same road preparing for serious injuries and surprisgnly the ride was firm but smooth! Just goes to show the correct valving with the spring makes a huge difference.
But she sits real high all round now... But I have figured out how to lower her and it will be done in due time. Hopefully I can find some NB tophats soon.
I don't want to come across harshly or rudely, but I think this is completely the wrong attitude to have.Furai wrote:Hopefully they will help you in good faith. I have been running my Watanabes (72ID)without hub ring locators, the only thing they do Is take the load off the stubs but they should work without them(I have done a Gymkhana with them like this). I usually would buy some for my wheels but after buying bits for my suspension Im a bit strapped for cash.
Firstly, Supercheap Auto have zero obligation to help at all as the issue was nothing to do with the wheel nuts supplied.
Secondly, this should be a clear example of why locating rings are so important. The weight of the car should be resting from hub to wheel center hole. The wheel studs are simply not intended or designed to take the weight of the car, and in clear contrast to what you say, they obviously should not work without locating rings.
Of course, the risk is one's own to take, but this should be a lesson for anyone with aftermarket wheels.
I can understand that and I know they are important, Im just saying that I have had no issues with mine. Im mearly stating a fact, I do not like to run without them but I dont have much of a choice at the moment.Mr. Shine wrote:I don't want to come across harshly or rudely, but I think this is completely the wrong attitude to have.Furai wrote:Hopefully they will help you in good faith. I have been running my Watanabes (72ID)without hub ring locators, the only thing they do Is take the load off the stubs but they should work without them(I have done a Gymkhana with them like this). I usually would buy some for my wheels but after buying bits for my suspension Im a bit strapped for cash.
Also hub rings are also sold in a rubber type plastic which would not take a huge amount of weight, would you consider these useless?
Oh, I'd assumed they were bought second hand.You might have a case against the shop you bought the wheels from if they told you they weren't required.chris wrote:So.... even though the shop I brought my wheels from told me I didn't need the locator rings... I am still fucked?
I'd be going back and talking to them, certainly.
There's no problem with you saying you haven't had an issue, but when you say something like "you should be fine without them" that's not a fact, because in the circumstances... well, it's obviously not fine. The seller told Chris the same thing and look where he is now.Furai wrote:I can understand that and I know they are important, Im just saying that I have had no issues with mine. Im mearly stating a fact, I do not like to run without them but I dont have much of a choice at the moment.
If there were mass stories of the rings snapping under the weight I might give that idea some credit, but I believe they're there to bridge the gap and transfer the weight from hub to wheel centre, not to provide any real structural support as such.Also hub rings are also sold in a rubber type plastic which would not take a huge amount of weight, would you consider these useless?
Mr.Shine, you are saying that the studs shouldnt take the weight but the studs didnt fail did they Chris?
The nuts would be taking the normal forces in a sideways motion even without hub rings. If the studs had failed I could understand but its the nuts that failed isnt it?
Angreal dont be jealous I now sit at the same height as all the cars around me
Ordinarily the hubs and studs both assist in locating the wheel and dispersing the weight of the car; without the wheels being hub-centric, the studs were insufficient and the nuts will have taken more force than they're meant to.Furai wrote:Mr.Shine, you are saying that the studs shouldnt take the weight but the studs didnt fail did they Chris?
It's well known that wheels are meant to be hub-centric or have locator rings attached. This is the reason why.
You're trying to say the nuts were still at fault, but the fact is they were used in an improper manner without hub locator rings.
Mr. Shine wrote:Ordinarily the hubs and studs both assist in locating the wheel and dispersing the weight of the car; without the wheels being hub-centric, the studs were insufficient and the nuts will have taken more force than they're meant to.Furai wrote:Mr.Shine, you are saying that the studs shouldnt take the weight but the studs didnt fail did they Chris?
Thinking about it does make sense.. Ultimate facepalm moment right now :'(
a quick bit of google-fu says the hubcentric rings are mostly for the older flat (non-conical) nuts.http://forum.miata.net/vb/archive/index ... 34069.html
true story - my '96 turbo and TE37's ran without the centering rings for quite a few years. No incidents...
Save that face palm until you find out what really happened. There is a lot of speculation and helpful suggestion being provided but until an engineer looks at it and determines what actually failed it is all just speculation.
This is a good idea, none of us(That I know of) are qualified to make any judgement especially without seeing the damage first hand.Euen wrote:Save that face palm until you find out what really happened. There is a lot of speculation and helpful suggestion being provided but until an engineer looks at it and determines what actually failed it is all just speculation.
Even though I may think Im an engineer
I'm an engineerFurai wrote:This is a good idea, none of us(That I know of) are qualified to make any judgement especially without seeing the damage first hand.Euen wrote:Save that face palm until you find out what really happened. There is a lot of speculation and helpful suggestion being provided but until an engineer looks at it and determines what actually failed it is all just speculation.
Users browsing this forum: No registered users and 58 guests
