OK next problem. I have steam coming out of the driver's
side windscreen heater vent. I'm thinking that the heater
core is leaking. How easy is it to get at that beast?
Should I get it repaired or visit Ross?
Don
Steamy interior
Steamy interior
Steamy interior
Ooop's - problem. If it is your heater core, regardless of wheather it can be repaired or needs replacing, the whole dash has to come out to get at it - no easy way around it unfortunately.
If you are in Auck would be happy too look at it for you.
Nigel
Nigel
Steamy interior
Take the engine out and cut a hole in the firewall if that's too hard
Adrian
Adrian
Steamy interior
Whichever route you take, (repair or replace) the entire dash has to come
out. I repaired mine about 6 months ago and it wasn't easy. It took a
couple of hours to take the dash out mainly because it took a while to find
the last bolt (in the middle below the windscreen). Trisha came out, took
one look and disappeared, it seemed the interior had been hit by a bomb!
Gordon.
Check out our website at http://www.tiptop.co.nz
Blast Away With The NEW Chill MEGABLAST. It's full of taste Explosions !!
CAUTION: This E-Mail message and accompanying data may contain
information that is confidential and subject to privilege. If you
are not the intended recipient, you are notified that any use,
dissemination, distribution or copying of this message or data is
prohibited. If you have received this E-Mail in error, please notify
ahelpdesk@tiptop.co.nz immediately and delete all material pertaining to
this E-Mail.
This footnote also confirms that the above email has been scanned for the
presence of known computer viruses as well as content considered unsuitable
for transmission.
Gordon.
this E-Mail.
for transmission.
Steamy interior
May seem like a silly question but are you sure its
steam? Some times the air conditioning can over cool
the air and it condenses to such a point that it
becomes cloudy. I thought id lunched a cooling system
once as all this white steamy air suddenly poured out
the vents! I dont think the air con will be in the car
much longer as we only ever use it a few times in the
winter to defrost the windscreen.
Steamy interior
Leaves a condensation on the screen and occurs no matter what the AC
setting is.
Don
setting is.
Don
