tehnzbrad
by tehnzbrad » Mon Oct 21, 2013 7:53 pm
i extended my AFM loom so it can reach across the engine bay and mounted the AFM vertically so the air filter is pointing at the ground have the idle control valve hooked up, but its just one 90 degree elbow then the AFM (idle control is plumbed into the 90 degree bend). Anyway started it up idles good not lumpy or anything, then i slowly depressed the accelerator and at about 1500-2000rpm the revs just drop off and it almost stalls, my pugs are fine and i checked for vac leaks etc, does any one know what it could be? im assuming its the AFM being vertical? some one help?
91 miata
- I only think 5.
by warrior » Mon Oct 21, 2013 8:53 pm
My afm is vertical and runs fine. Check the wires you have made longer?
- I only think 5.
by warrior » Mon Oct 21, 2013 8:57 pm
Oh sorry did you say it was pointing towards the ground? yeah then it could just be the weight of the flap making it not work correctly.
by SLYDIT » Mon Oct 21, 2013 9:46 pm
make sure your flapper isnt sticking.
- I only think 5.
by warrior » Mon Oct 21, 2013 10:13 pm
Yeah you never want a sticky flap
tehnzbrad
by tehnzbrad » Mon Oct 21, 2013 10:42 pm
used my multi meter to test the wires and they are allg, ill give my afm a good clean it doesnt look to be sticky but ill give that a try, ill just revert back to stock if it doesnt work out, cheers
91 miata
