Clutch recommendations
Post by Angreal » Sat Jul 14, 2012 7:11 pm
Is it simple to change clutch/fly wheels? I guess it's time consuming and you need the right equipment?
Post by siren676 » Sat Jul 14, 2012 7:23 pm
Looking at a workshop manual it doesnt seem like too much of a big job, will just take a while.
Have been told to get the flywheel ground for the new clutch so will have to take it into work with me as i work across the road from franklin cams.
Looks like a basic spanner set would almost be enough to do the change
Zadkiel
Post by Zadkiel » Sat Jul 14, 2012 8:05 pm
siren676 wrote::twisted: This is going to be sweet
Nice. By all accounts aligning it is the hard part
Post by WideOpenThrottle » Sat Jul 14, 2012 8:26 pm
siren676....Looks like a basic spanner set would almost be enough to do the change
And a decent socket set with universal socket plus extra extension bars to reach up to the top Bell-housing bolts!
Probably a power bar too if it hasn't been off for awhile.
And dont forget to do the rear crank oil seal!
And a torque wrench for re-installation of everything.
Post by siren676 » Sat Jul 14, 2012 8:31 pm
Should i grab an alignment tool to help with the install?
Will grab the oil seal and probably some new gearbox oil while im at it
Post by WideOpenThrottle » Sat Jul 14, 2012 8:39 pm
Can do but its no biggie if you dont have the alignment tool..i use a socket or something similar...sometimes you fluke just by eyeing it!
If you want to keep your oil in the gearbox then there is a special plug that goes in the end of the gearbox or use an old drive shaft front yoke to plug it otherwise oil pours out everywhere and all over your Sunday best! :D
Post by siren676 » Sat Jul 14, 2012 9:07 pm
Want to change the oil anyway as i dont know the service history of the car.
When doing the clutch in my starlet i eyeballed it and the gearbox went straight on so mustn't be too bad at it :lol:
