13B Mild Port.
MX5 13B
13B Mild Port.
Post by MX5 13B » Sat Nov 28, 2009 5:51 pm
MX5 13B
13B Mild Port.
Post by MX5 13B » Sat Nov 28, 2009 6:26 pm
This was my bridgeport engine but was to wild to drive.
http://www.youtube.com/watch?v=7wlXJIQwIMA
This the new engine set up. Much smooth to drive.
http://www.youtube.com/watch?v=n4l66qpZ6s0
More vid of mild port
http://www.youtube.com/watch?v=4NolTERBomA
dynofiend
Post by dynofiend » Sat Nov 28, 2009 9:53 pm
Awesome! Is it certed yet? Fab work looks really professional, great job.
MX5 13B
13B MX5
Post by MX5 13B » Sat Nov 28, 2009 10:52 pm
Will take it for cert in feb. I have to fix a few thing that are not working.
I am getting a new drive shaft made and have to replace rear seal ,its leaking gearbox oil. Have to sort the speedometer , am using a rx7 fd gear box and it is electronic pickup. am getting a fc speedo drive and will try it in a few weeks. have to put a heat shield by extractors the brake and fuel lines are to close. It should get a cert easy. :) :?:
dynofiend
Post by dynofiend » Sun Nov 29, 2009 9:44 am
Good stuff. I noticed the baffles on the exhaust pipe. I take it that was the final solution to the noise issues you were having?
MX5 13B
13B Mild Port.
Post by MX5 13B » Sun Nov 29, 2009 11:50 am
Yes i used a super trap muffler and it is real quiet.
Post by sprsta » Mon Nov 30, 2009 7:44 pm
i have an nb instrument cluster spare wich has electronic speedo
MX5 13B
MX5 13B
Post by MX5 13B » Wed Feb 10, 2010 11:09 pm
Hi all. Just went for cert on the mx5 . Have failed on some basic things like not having lock washers,need a drive shaft loop,need to make bottom mounts for my radiator and have to lift my gearbox to correct my driveshaft angle. Hoping to have it all corrected in two weeks. Not long before its legal.
:) HA HA i wish.
MX5 13B
13B mx5
Post by MX5 13B » Wed Apr 07, 2010 10:02 pm
All legal now . have got cert . :)
Going to oz for a few months , hope to take it to spring hill when i get back.
Post by sprsta » Thu Apr 08, 2010 6:27 pm
couple more than two weeks but thats all good
just in time for winter
MX5 13B
13B mx5
Post by MX5 13B » Fri Apr 09, 2010 9:25 pm
Yes i know its more than two weeks. Thats what you get for having more than one project on the go. Have sold my 1979 VB 308 holden commodore. Have got the mx5 sorted now in the process of getting my rx8 going with the new engine conversion . :)
MX5 13B
13B mx5
Post by MX5 13B » Fri Apr 09, 2010 9:33 pm
12a MX5
Post by 12a MX5 » Tue Apr 13, 2010 5:34 pm
How much was the cert if you dont mind my asking? Did you need a drive shaft loop because u have a modified shaft/non o.e gearbox or is it just a cert requirement for any modified car?
Rotor Powered NA6
Post by sprsta » Tue Apr 13, 2010 6:15 pm
my cert cost about 500 all certs are pretty much the same
most certifiers will ask for a drive shaft hoop as you are adding power to the engine
i had to for my turbo
its crazy you can put the engine and full running gear from a skyline into a silvia and still need a hoop
i think its just to be on the safe side
Post by sprsta » Tue Apr 13, 2010 6:17 pm
is it going to be an RXV8??????
MX5 13B
13B mx5
Post by MX5 13B » Tue Apr 13, 2010 10:56 pm
It cost me $600 to get cert. I am putting a 13B JC Cosmo Turbo engine in the rx8. Going to oz on saturday and will buy a ecu to suit .
Post by Timmo » Wed Apr 14, 2010 10:52 am
Whats the difference between a Rx7 13b and the Cosmo version?
12a MX5
Post by 12a MX5 » Wed Apr 14, 2010 5:28 pm
Not much Difference between the engines, both '92 + rx7s(batmans) and jc cosmos came out 13b twin turbo, but the JC came out with bigger intake ports i think, and have a better looking intake manifold ,in my opinion. 8)
Rotor Powered NA6
