Ford Econovan timing diagram
Post by WideOpenThrottle » Sun Dec 30, 2012 9:18 am
I know this is a long shot but does anybody have the repair manual for a 1981 Ford Econovan 1.6 litre SOHC 8 valve?
Thought i had it all sorted but have absolutely no compression on any cylinders now that the heads back on.
Post by SLYDIT » Sun Dec 30, 2012 12:51 pm
pinto engine? tried a cortina engine manual?
Post by WideOpenThrottle » Sun Dec 30, 2012 1:31 pm
Cheers Slydit...i had been going off 1500 ford laser book that i have got but wasnt sure how much i could trust it!
I have got compression now after re-adjusting the valves [havent done that for a millenia]!!
They were miles out as came back from the reconditioners & i never checked them initially....so hopefully it will fire up soon.
Pain of a job as you have to remove the drivers side engine mount,then lower the engine just to have clearance to take the rocker cover off :roll: and remove the radiator to be able to turn the crankshaft pulley for timing. :D
Post by SLYDIT » Tue Jan 01, 2013 9:46 am
Sorry was just re reading that and saw it was an econovan...i was thinking transit for some reason. I guess the mazda 1600 is the same as the b2000 utes??
Post by WideOpenThrottle » Tue Jan 01, 2013 10:45 am
All good & running! :D
Users browsing this forum: Bing [Bot] and 9 guests
