wont idle
tim.maggie
wont idle
Post by tim.maggie » Tue Oct 18, 2005 8:48 am
Hi all, a friend also with a 1600 NA mx5 is having trouble with his idling -
in fact the it wont! The idling adjustment has been wound all the way out but
it makes no difference. He has been told that there is some sort of valve
somewhere that is carboned up and needs cleaning. Have any of you heard of
this and what it might be? Or have any other ideas on what the problem could
be? Tim
From jifjif@gmail.com Fri Apr 27 17:27:51 2007
b=U8ag7B/fMcln7REDVTbVl1T0CFrJGBsAn5Gn73Itmt0SzBebnQLLWaLf9mqtln0kEp7TfW7+Wd7KwlJ4mcOPG+iM3Uk5X5wjpHtDURR/+Te4giLdyuURW1iWPdNt4D2YKfpptVsNooj7YVV4me5Ur+hqPYOsjRw1nueMGZveTg8=
Date: Tue, 18 Oct 2005 09:51:19 +1300
Subject: Re: wont idle
In-Reply-To: <000801c5d353$c93a13a0$95cf36d2@maggie>
References: <000801c5d353$c93a13a0$95cf36d2@maggie>
Message-ID: <lePhAB.A.HAE.ExYMGB@L733>
won't idle "full-stop" or needs some accelerator prodding to stay running ..?
On 10/18/05, tim.maggie <tim.maggie@xtra.co.nz> wrote:
tim.maggie
wont idle
Post by tim.maggie » Tue Oct 18, 2005 10:34 am
Hi Jeff, yes it needs to have a foot kept on the accelorator to keep it
running.
wont idle
Post by zorruno » Tue Oct 18, 2005 11:35 am
idling - in fact the it wont! The idling adjustment has been wound all
the way out but it makes no difference. He has been told that there is
some sort of valve somewhere that is carboned up and needs cleaning.
Have any of you heard of this and what it might be? Or have any other
ideas on what the problem could be? Tim
When adjusting idle, did they do the required jumpering on the ECU
connector (in the engine bay)? I believe you have to connect TEN & Gnd
to tell the ECU the new idle setting - as per adjusting timing. Someone
please correct me if wrong.
H
KSCRIM
wont idle
Post by KSCRIM » Tue Oct 18, 2005 12:24 pm
Correct, the connector jumper is required. However it may well be that the
air bypass in the throttle body is blocked and the T/B needs cleaning. There
is a procedure for doing this in the Miata.net garage forum. Note the
warnings carefully as to the cleaners NOT to use. The procedure for the idle
setting is also there. Look under "Idle Droop"
I found the butterfly stop set wrong on my 98NB 1600 and so the throttle was
sticking shut.
I reset the stop to just above catching.
Kevin 98NB6C
Okibi
wont idle
Post by Okibi » Tue Oct 18, 2005 7:49 pm
Take a look at the AFM plug, make sure it's not loose, or full of gunk /
corroded
- Dave.
Okibi
wont idle
Post by Okibi » Tue Oct 18, 2005 8:23 pm
BTW - the fuel pimp doesn't run without the AFM signal - so I've
discovered...
A fuel pimp? Fuel's not THAT expensive.
- Dave.
From jifjif@gmail.com Fri Apr 27 17:27:40 2007
b=MkEXce7aCEi0QSXiv78a+7wz77zkmgk5u/fTxKxW4ubzuYsFmSb31SrpKTwXDFlX3r3DMzA9N3j9HBKXqjCxrxn1TzDb44PByYJarnkizcgNqfzaPfFdsqvPVctV0QcVegLYD5t0pEJjsyPA0+hltJ48Qq04pQXrt86mlKF2PWc=
Date: Tue, 18 Oct 2005 20:33:54 +1300
In-Reply-To: <200510180723.j9I7NYM27548@plus43.host4u.net>
References: <363634910510180012h349a08f8l80e819bac2bd25d0@mail.gmail.com>
Message-ID: <WqhzsD.A.aAE.ExYMGB@L733>
when you see those cars "kerb-crawling" through the red light district
... there's your fuel pimp right there ;-)
tim.maggie
wont idle
Post by tim.maggie » Tue Oct 18, 2005 10:01 pm
Hi David, thanks for replying - what is an 'AFM' plug?
wont idle
Post by poison » Tue Oct 18, 2005 10:13 pm
Air Flow Meter is an AFM and sits to the left front of the engine (Left being
passenger side) and measures how much air goes into the engine so the computer
knows how petrol to give to the engine.
PO1SON
Okibi
wont idle
Post by Okibi » Wed Oct 19, 2005 4:05 am
b" Hi David, thanks for replying - what is an 'AFM' plug?
See diagram below
http://www.arach.net.au/~creative/afm.jpg
- Dave
Return to “2005”
