diff problems
daca.robinson
diff problems
Post by daca.robinson » Mon Jan 17, 2005 10:18 am
Hi everyone.
I've been a regular reader of this forum for many years but as yet not really had any problem with the mx5,until this week-end, my car is a 1990 model with aprox 130,000 kms has started to make a loud clunk at the rear end when doing a U turn from a stand still and both rear wheels are making small shudder's when pulling away in a straight line.
I suspect the diff, any advise would be great & alternative diff type which would fit.
Many thanks.
Dave Robinson
diff problems
Post by poison » Mon Jan 17, 2005 2:05 pm
When doing a U turn, press the accelerator firmly to the
ground and the clunk will not be heard over the squeeling of
the tyres... all good :-)
"PO1SON"
From jifjif@gmail.com Fri Apr 27 17:15:44 2007
h=received:message-id:date:from:reply-to:to:subject:in-reply-to:mime-version:content-type:content-transfer-encoding:references;
b=G73xCriWtwC6DCPbvHKRLzeeKjjb+0OZdGl+wp9PUTFcfo7hD+BZ2p/Hre22L3+kNSPYCNakL7yR0ivAeT1OyFaQh+1SVNe05/LtUcFLOEpWLe6qTxi2X1NIaALDqjD8vZG2ozjcFDJfLMLAiujbvVXmUuzpuCu7RQ3sqXG+3h8=
Date: Mon, 17 Jan 2005 15:38:10 +1300
Subject: Re: diff problems
In-Reply-To: <41eb0f4f.175.797a.181884979@ihug.co.nz>
Mime-Version: 1.0
Content-Type: text/plain; charset=US-ASCII
References: <41eb0f4f.175.797a.181884979@ihug.co.nz>
Precedence: list
Message-ID: <nbMabB.A.1n.QdYMGB@L733>
... and then when the smoke clears, get your wrenches/sockets out and
tighten down the shock and sway bar mounts ! Cheap'n'easy ...
EricW
diff problems
Post by EricW » Mon Jan 17, 2005 5:25 pm
Yeah, I was going to make the same suggestion, Diffs tend to make continuous
noise, a clunk or shudder tends to suggest something is coming loose,
particularly under high torque conditions
Stick it up on a couple of axle stands and tighten things up, but also have
a look for any thing that might have broken, or bushes that are flogged out.
Eric
Josh Woof
diff problems
Post by Josh Woof » Mon Jan 17, 2005 7:01 pm
HI
I have an 89 mx5 but have fitted it with a more powerfull motor and after
giving it a good rev off at the lights one day the carrier arm holding the
actual diff just snaped off problem solved by welding it up.
David & Judy Kerr
diff problems
Post by David & Judy Kerr » Mon Jan 17, 2005 7:50 pm
Dave have you looked at something other than the diff? Another idea could be
the handbrake. If this is sticking and holding on it will make a similar
noise when it lets go.
Dave Kerr.
Return to “2005”
