Hi all
How long should it take to recharge the battery on an MX5? I've been away
for 3 weeks, came back to find the battery completely flat. The AA man paid
a visit, got the car started and said the battery appeared to be charging OK
and suggested I drive it around for at least half an hour to recharge it. I
had no problems with that suggestion (just a shame that the weather's not
better in Akld today) however when I stopped, the car wouldn't restart. Got
a push start and then drove up an down the motorway for another 40 minutes,
only to find when I got home again that the battery was still not that
enthuasiastic about starting the car... Do MX5 batteries take longer than
ordinary ones to recharge, or is this a sign that either my battery is dead,
or that the alternator isn't holding the charge??
Thanks in advance
Joanne
charging the battery
18-24 hours at TWO amps... NO HIGHER THAN TWO AMPS!!! A fast charge can
kill that battery.
kill that battery.
Sorry Adrian but I think a new battery is indicated. When mine went like that (it was not an MX5 batt.) when pulled out it was only 1/2 full of water and the other half was sulphate!
Your battery will be fine, as long as you have the original MX-5 battery do
this... (DONT LET ANYONE PUT IT ON A REGULAR BATTERY CHARGER THOUGH!)
Buy yourself a trickle charger from Repco, they're a plug pack with leads
and clips. They deliver about 1A.
Put the battery on that (take out of car first) for about 24 hours, 36 if
you can.
Put back in car and all should be well.
My battery is 10 years old, and has been rescued like this twice, and is
still going strong.
Gary
you can.
still going strong.
Gary
The MX5 battery may appear dead, but can usually be revived with the correct
procedures
a couple of good links about mx5 battery charging are
http://www.miata.net/garage/jumpstart.html
and http://www.miata.net/garage/battery.html
oh and if you still need info, many more links about batteries in general
here:
http://uuhome.de/william.darden/batlinks.htm
procedures
here:
Others have given excellent advice but possibly not really answeredstarting the car... Do MX5 batteries take longer than ordinary ones to
these questions:
charged by a charger. Just driving around won't do it. Chargers areFrom personal experience, it's probably fine, but needs to be trickle-
MUCH cheaper than a new battery.
OTOH if yours is an import, bear in mind that the battery is probably
already at least 5 years old - so maybe a replacement is called for.
Users browsing this forum: Bing [Bot] and 22 guests
