Soft tops....
Ozzy
Soft tops....
Post by Ozzy » Fri Jan 09, 2015 2:02 pm
Was wondering, would a soft top from a 1999 NB fit on to a 1989 NA?
jtsoldier
Post by jtsoldier » Fri Jan 09, 2015 2:13 pm
Apparently, yes. Never done it, so no idea how much work is involved, however.
You might want to take a look here: http://www.miata.net/garage/compatibility.html
EDIT: Here's the write up on how to drop the entire thing on (frame included), also courtesy of miata.net's garage: http://www.cienega32.com/miata/nb2na/nb ... xplant.htm
Ozzy
Post by Ozzy » Fri Jan 09, 2015 2:36 pm
Thankyou so much for the links! Off to read them now!
Post by SLYDIT » Fri Jan 09, 2015 10:37 pm
If you swap the entire system including the hoops and header clips then yes
Toolbox
Post by Toolbox » Sun Jan 11, 2015 12:42 pm
Yes it does fit done it a few times, because the rear window is glass and you are fitting it to a NA model which had a plastic rear window you will need to fit
a control strap kit so the rear glass window works when you lower the hood. The best way is to fit the NB frame too.
Post by marcellarius » Mon Jan 12, 2015 9:19 am
The NB hood and frame is a nice upgrade vs. the NA top. The NB frame is subtly different: the rear bow is sprung and pivots in a slightly different place from the NA which helps the glass window slide smoothly into place as you open the hood.
Users browsing this forum: Bing [Bot] and 39 guests
