Megasquirt guru wanted
lancec
Post by lancec » Mon Nov 25, 2013 10:08 pm
Hey guys I am looking for a Megasquirt guru ideally located in wellington or palmerston north or anywhere in between.
I have a megasquirt that has been used in an mx5 in the past and I want to get it ready to use in my car and get some help understanding what it can and cant do for me.
Then I can start getting parts for my turbo build :twisted:
It will be used in my 98 NA8
Does anyone know of such a guru?
Thanks!
:D
Post by SLYDIT » Mon Nov 25, 2013 10:48 pm
what sort of megasquirt is it? MS1/2/3/PNP???
the wiring is different from 1600 to 1800 cars. and youll need to check the ignition drivers and the idle valve circuit. youll also need a variable tps from either an auto car, or an E30 BMW
Post by WideOpenThrottle » Tue Nov 26, 2013 7:29 am
Try Jared..he is yery helpful although he is in Tauranga
teamjelly@hotmail.com
BERGRR
wow first post haha
Post by BERGRR » Sun Jan 26, 2014 7:17 am
He shouldn't need a vtps if its NA8 it should have one already, my 93 NA8 had one any way.
but yeah what MS you have changes things a bit, I did a DIYPNP, wasn't to hard, good luck to you :D
Post by Angreal » Sun Jan 26, 2014 10:21 am
He should have a vps already
