overheating
overheating
i have an mx5 that i have recently purchased the problem is running around the temerature is fine ,but when i go out on the open road the temerature increases dramtically.i have had the water pump replaced and thermostat replaced ...the dealer has had the radiator cleaned ....but i still have the same problem can anyone help
I had simialr issues with my number plate being in front of the radiator opening....
Maybe trying with it off or relocated could be a worthy test, if it is in that position.......
I would also ensure you have the pastic undertray installed. From my research, some cars dont respond well to this not being there....I removed mine and made an aluminium undetray so I have a spare you could borrow, possibly have.
Yeah that's a good thing to check, just undo the pipes in the engine bay at the firewall & give it a flush through.Growler wrote:Also check the small radiator under the dash. These can block up and reduce the flow as well...
-hope it's not that though, coz you have to pull the whole dash out to remove the heater matrix!
I don't have my plastic drip tray installed and have never had any heat issues, and that includes some fairly hard driving...Mad Kiwi wrote:I had simialr issues with my number plate being in front of the radiator opening....
'96 Celica - Because DD
Be very careful removing the hoses. The pipes going onto the firewall are aluminimum and are very soft!tomtikki wrote:Yeah that's a good thing to check, just undo the pipes in the engine bay at the firewall & give it a flush through.Growler wrote:Also check the small radiator under the dash. These can block up and reduce the flow as well...
