Petrol Fumes
Petrol Fumes
Post by Donovan » Tue Oct 09, 2012 8:24 pm
I am still getting petrol fumes in the cabin even though I am sure I have blocked/plugged up any possible point that it can come in,
Now I am thinking that there is something wrong somewhere (just for a change) after the conversion. There is a strong petrol in the boot when I open that up, and to be honest I wouldn't have a clue whether it is normal or not (I am guessing not) for an early NA to have this.
Any one got any comments on this.
The fuel pump has been replaced/upgraded to feed the best so now just wondering there is something to do with seal on top of the tank?
Post by Angreal » Tue Oct 09, 2012 8:32 pm
Definitely not normal. I thought the fuel tank was a sealed system though.
Post by Snapfrozen » Tue Oct 09, 2012 8:46 pm
Have you removed your charcoal canister?
Post by Donovan » Tue Oct 09, 2012 8:52 pm
Charcol Canister? Is that the black canister in the engine bay, if so, man that is long gone, no room for that anymore. But that's a long way away from the boot.
Post by Donovan » Tue Oct 09, 2012 8:54 pm
Angreal wrote:Definitely not normal. I thought the fuel tank was a sealed system though.
Can't be completely sealed, isn't the fuel pump submerged into the tank?
Post by Born_disturbed » Wed Oct 10, 2012 10:36 am
I get a slight smell of fuel in my boot too, worried me when I first bought the car but my tank is all leak free so not sure?
Post by Donovan » Wed Oct 10, 2012 10:55 am
Problem is that it is starting to get quite strong now, I can't sit in the car for more than 15 mins or so when it is sitting still without getting a headache.
Post by tomtikki » Wed Oct 10, 2012 11:08 am
You could put avgas in, ive always loved the smell of aviation fuel...
Post by Snapfrozen » Wed Oct 10, 2012 11:58 am
Depending on the model of your car, the charcoal canister can cause it. Might pay to trace the hard lines that you block off and see if theyre venting somewhere like the boot, or if one of the venting lines has come loose?
Post by chris » Wed Oct 10, 2012 12:07 pm
Snapfrozen wrote:Depending on the model of your car, the charcoal canister can cause it. Might pay to trace the hard lines that you block off and see if theyre venting somewhere like the boot, or if one of the venting lines has come loose?
Is this for the LS1 Donovan?
Post by Born_disturbed » Wed Oct 10, 2012 12:20 pm
Yes it is
Post by Kieran » Wed Oct 10, 2012 12:25 pm
I removed my charcoal canister ages ago and just looped the lines
I don't smell fuel in my cabin at all so unless you didn't loop the lines and disconnect the sensor attached to it then that shouldnt be the problem
Post by Euen » Wed Oct 10, 2012 12:38 pm
Check the valve in the top of the tank that is normally connected to the charcoal cannister. If the hose has been removed it may be leaking a bit. When I removed the one from the TG I replaced it wih a blank aly plate and and new cork gasket and used Loctite 567 on all the screw threads. Petrol will find its way through unsealed screw threads even if you think they are tight.
old scrubber
Post by old scrubber » Thu Oct 11, 2012 8:10 am
petrol and lpg fumes are the most volitile around, below 7% wont ignite, above 70% is saturation wont ignite, all you need is a stray spark and boom, personally i would not drive the car untill i fixed it real fast . :(
Post by Donovan » Thu Oct 11, 2012 10:06 am
old scrubber wrote:petrol and lpg fumes are the most volitile around, below 7% wont ignite, above 70% is saturation wont ignite, all you need is a stray spark and boom, personally i would not drive the car untill i fixed it real fast . :(
Well the not driving it isn't a problem, It's usually 2 or 3 weeks off the road after a track day fixing all the things I broke on it :roll:
Post by Donovan » Wed Oct 24, 2012 9:46 pm
So poking around trying to find where the fumes are coming from, is it ok to have that line blocked off the way it is?
Post by SLYDIT » Wed Oct 24, 2012 10:14 pm
the vent for the tank is there for a reason.
petrol sloshing around in a tank creates vapour that needs to be released.
without it your tank is a sealed system that just keeps building pressure. Reconnect your vapour recovery canister and port it intto the inlet manifold.
Post by WideOpenThrottle » Thu Oct 25, 2012 9:10 am
Dont forget you have a breather pipe next to the filler pipe that allows the tank to breathe....so on a warm day when the petrol heats up & expands a little then fumes will naturally be noticeable.
Post by WideOpenThrottle » Thu Oct 25, 2012 9:47 am
Did you have your charcoal canister removed by the crowd that did most of your mods? if so they probably blocked it off.
Mine doesnt have the charcoal cannister anymore but is still vented at the the engine bay similar to how it was from factory.
Post by Donovan » Thu Oct 25, 2012 9:56 am
WideOpenThrottle wrote:Did you have your charcoal canister removed by the crowd that did most of your mods? if so they probably blocked it off.
Yes, the place that did the engine conversion removed the charcol canister and would have blocked that line.
Post by Kieran » Thu Oct 25, 2012 9:57 am
Yeah you just loop the lines
