Roll bar legality
Roll bar legality
I see a lot of roll bars that end up being bolted into the seatbelt towers and then welded or plates welded on the back tray.
Does this require a cert? I just read through the Low Volume Cert documentation and cant seem to find an answer, if it doesnt weaken the structure and meets the requirements for roll bars in general it would seem not?
Can anyone clarify or does anyone have any personal experience?
Im really hoping to A.) not get in any trouble with Johnny law and B.) Not get a cert.
To clarify I will be building one with a friend who races a lot of cars and has all the tools and experience required to do this but normally does it for motor racing applications.
For clarity, there is no mention of any differentiation in the WoF VIRM or LVV cert thresholds between bolt-in and weld-in roll bars. Requirements are:
• each seating position is fitted with an effective head restraint, and
• the bars are positioned:
– behind, following a plane extending upward, parallel to the back of the backrest on the rear‑most seat, and
– in such a way that the head restraint would provide protection from head contact with any bar section during a crash.
Denz...I assume from your association with your mate, that you appreciate that a Motorsport Association of NZ approved roll protection is a whole different ball game and needs a different approach.
According to LVVTA, a roll-bar:Snapfrozen wrote:Sorry, misread the post on my phone, my post would apply to a rollcage/half cage, not rollbar
"means a transverse bar, or bars, positioned behind the front seating positions, which is attached and laterally braced to the main structure of the vehicle."
Whereas a roll-cage:
"means a roll-bar with additional members extending forward past the
front seating positions to another roll-bar positioned around the top
of the windscreen area."
So there's still no differentiation between weld-in and bolt-in as far as the VIRM for WoF or certification thresholds are concerned
Im in hamilton, im going to try and take lots of photos, its a mate thats doing it as a bit of a favour but i'll post pics up etc etc im sure there will be a lot of trial and error but i'll try and do a "what we did" rather than walk through and will be more than happy to show it off when its done.
When I figure out how to put a subwoofer in this damn thing i'll do a walkthrough aswell.
Edit
Well there seems to be a bit of interest so i'll see if we can make it a bit more bolt in and if he would want to sell any of them etc
Edit
Yes at best im hoping this might get me into a funday on a track if not its for protection, chassis stiffening and looksIan wrote:Denz...I assume from your association with your mate, that you appreciate that a Motorsport Association of NZ approved roll protection is a whole different ball game and needs a different approach.
The style will be Harddogesq still look with maybe some extra bracing for the rear.
Edit:
Without actually taking everything off and measuring the initial ideas are as such, most likely is the bottom left or slightly closer to the center and have no pinning.
1.) Safety (has to be better than having nothing)
2.) Useability (easy to build, install, live with every day and hopfully remove)
3.) Looks (a basic hardbar doesnt do it for me aesthetically but I will work around the first two)
Edit 7million
He seems to be semi keen on the idea of making a couple extra depending how it goes
Here's some cheap versions on trademe...
http://www.trademe.co.nz/motors/boats-m ... 010195.htm
I'll go and see if there's anything I can find at work, we sell Fusion products.
Users browsing this forum: Google [Bot] and 76 guests
