Noob with a question, NB8A RS or NB8B?
Stoyak
Post by Stoyak » Sun May 22, 2011 4:58 am
Hi all,
I'm originally from Aus but I'm going to be working in NZ for a while and am looking at taking advantage of the cheap(ish) import car scene here.
I own a Clio 182 Cup in Australia so I wanted something that will handle as well as it does without throwing money at it and I figure the perfect car choice is an MX5. Plus I don't want to die without owning and experiencing one!
I'm looking at two in paticular at the moment and I'm wondering which one is the better option.
First one is a 2000 MX5 RS 1.8. (It's definitely pre 2001 facelift so am I correct calling it is an NB8A?)
As I understand it comes from the factory with a Torsion LSD, Biltein Suspension, bigger ARB's, front strut brace, and a 6 speed box.
Second is a 2001 MX5 1.8.
This would be the facelifted NB model with the more powerful 1.8L engine, 6 speed box and stiffer chassis (and maybe bigger brakes, not sure). I'm yet to find out from the owner if it had the LSD option but I don't think it does.
I'm just not sure what path is better. Given a choice of the two is the NB8A RS good enough over a NB8B?
Stoyak
Post by Stoyak » Sun May 22, 2011 5:40 pm
I actually test drove the RS today and its really nice, very tight. Only eyebrow raise was when chucking a tight u-turn, under mild throttle it sounded like the inside rear let out a bit of a screech. Now the car should have the Torsen LSD so is that just a case of a turn to tight for it to work effectively or something? I just hope it doesn't indicate that the car has had its LSD removed because that would be ridiculous.
Going to try and line up a drive of the 2001 NBB for next weekend.
Post by brownie » Sun May 22, 2011 9:24 pm
They all run NB8C chassis codes here,If it's a Jap import,Unless you find a 1600cc model,Plenty of those around.
Just remember they are ROADSTER's if import or MX5 if NZ New.
fiveisalive
Post by fiveisalive » Mon May 23, 2011 7:48 pm
Sorry to hijack the thread but...
Are the 98-2001 RS2 models only 140hp? and the R2.5 160hp and heavier?
Stoyak
Post by Stoyak » Mon May 23, 2011 9:44 pm
Yeah that sounds about right, i think its something like 142hp and 158hp.
Weight wise I think the R2.5 was slightly heavier ~40-50kg.
fiveisalive
Post by fiveisalive » Mon May 23, 2011 9:58 pm
Ah nice cheers for the clarification.
Nice ride the 182. I looked at getting an RS back in the day ... I got sick of waiting for the dealer to source me one so I ended up with a 1996 Peugeot 106 Clubsport/Rallye instead.
Stoyak
Post by Stoyak » Mon May 23, 2011 11:12 pm
Yeah I'm keen to see how the MX5 handles compared to the Clio.
It's got a good benchmark to live up to as I guarantee the Clio will handle better then anyone who hasn't driven one would ever think :)
dynofiend
Post by dynofiend » Sun May 29, 2011 10:29 pm
fiveisalive wrote:Ah nice cheers for the clarification.
Ive owned one of those too, 1995 white one. Also had a couple of XSi's in my time :)
fiveisalive
Post by fiveisalive » Thu Jun 02, 2011 12:09 am
Yeah I love the 106's... :D
