No spark... possibly CAS broken
Was driving happily yesterday morning, but in the afternoon the car would not start and had to have it trucked home.
Compression, oil pressure, and cranking all fine - a screwdriver to block test shows no spark.
Suggestion given to me is likely cam angle sensor - this is a 1.8L 94 and apparently they go sometimes... any other thoughts? It does have supercharger and an aftermarket/piggyback ECU - been going fine for months but I'll check the wiring too.
Plan to see if I can get it out ok - looks simple enough from notes here:
http://forum.miata.net/vb/showthread.php?t=49417
Any other help welcomed - does anyone have a spare CAS for a 1.8 sitting around? Otherwise I'll try wreckers - I'm guessing new will be expensive!
H
(If it was driveable I'd just take it to Autoway...)
H
Could also be the coils however it would be unusual if both of them went at the same time. If your coils are the 3 wire variety I have a spare you can borrow. Don't have a spare CAS though unfortunately.
There used to be a company in Nelson that advertised replacement internals for the CAS. I posted the link to their website on here some time ago but don't have it to hand any more. I'll have a hunt and see if I can foind them again.
Edit: Found it http://www.anythingelectronic.co.nz/rep ... ign&menu=1
Alternatively, check with Steve at Milford Auto Electrical, he may be able to suggest something.
Good luck.
Good luck.
Yea ive had the same problem on my 93 1.8, had the car parked on the street then moved it into the driveway, then wouldnt start.
Everyone told me the 1.6 & the 1.8 CAS are different but a mate had his 1.6 there & said "
hey it cant hurt to try it can it
so tryed it & she was away
ended up getting one off a wrecker for about $90
Re: No spark... possibly CAS broken
you mean the entire housing is the same? Or just the inner plastic part with the sensors...PLSEME wrote:Everyone told me the 1.6 & the 1.8 CAS are different but a mate had his 1.6 there & said "hey it cant hurt to try it can it
CAM sensor part Mitsubishi number J825 is what you need,
Not all NA6's have those,most have a J925,completely different.
The housing is different as well.You won't know what a 1600 has until you pull the cover off.
J825's are in a variety of Mazda's ,Familia's,DOHC FE,F8 Capella's ,Proceed's
We are in the process of sourcing these from Taiwan ,Couple of months before we will see them though
Yea i was told the internals were different,
But there is a little difference in the shape when there side by side but it seems to work
Hmmm, unfortunately the CAS doesn't seem to be the problem. It took me about an hour to get a second hand one installed.... it is a real pain to seat properly. Lots of Vaseline needed and patience. Was about to remove the rocker cover when finally it fitted.
The engine seems to have the same problem... it looks like it may be lacking power to the aftermarket ECU dammit. I didn't install it so some tracing needed.
Incidentally, most wreckers are useless... I phoned 4.
MAZBITS FOR MAZDA - said they should have one - they'd check and ph me back. Never heard from them again.
Parts Connection Onehunga - said definitely wouldn't have one and wouldn't know who I should talk to.
I phoned one in the yellow pages that said they were all over Auckland... they are based in Rotorua but can send parts. They were going away to look... and never phoned me back.
Mazspare, 747 Rosebank Road, Avondale, Auckland -
PH: 09 828 9001 - spoke to Robbie. Not a problem, he knew the unit and asked the right questions - $89+GST. Had it all ready to go when I arrived. Thanks Mazspare.
http://www.mazspare.co.nz/
Have you tried Ross at MX5 Mart, He always seem to have what I want for my NA & NB.
