Hi Gaba
There are three rubbers on each side, you can get them from Mazda. I can't
remember the cost now, but do remember having a heart attack at the time.
Something around a hundred bucks each I think!
leaking
leaking
Hi,
My car had a leak on the top in the corner at the drivers side where the soft top clips in. Ive adjusted the top and this leak is ok now but unfortunately this has resulted in another leak.
The new leak is also at the drivers side where the rubbers seal against the window. The leak is in the middle where the rubbers look like its cut of course to allow it to bend when the top is taken down.
Does this mean I have to replace the top or can only these two rubbers be replaced? And if so where do I get these rubbers?
Is there someone who has experienced the same problem and has a solution for me?
Gaba
Gaba
