Battery dies on turn off
I seem to be having a bit of an odd problem...
Every now and then, ususally after heavy usage, the battery in my '89 NA dies when i turn the car off... but only for a few minutes...
I will turn the car off and everything will go dead... head unit, ignition, lights, alarm... everything.
after about 3-4 minutes it all just starts up again. It wouldn't be so concerning as it is intermittent but it means that I have to set up the head unit every time it starts up again.
Has anyone had this problem before? Does anyone know what it could be?
Any help would be much appreciated.
Thanks.
Thanks.
on 6/11/2009 3:05 p.m. Hojo wrote:
I'll put $10 on "dirty or worn connections in the ignition switch"
Spray a bunch of contact cleaner in there or something.
place your bets...I seem to be having a bit of an odd problem...
If the radio is losing its settings then, providing it has been installed properly it points to the direct feed from the battery as others have suggested. The head unit should have 2 power feeds, one from ignition/accessory positon and the other direct from the battery. It will only lose its settings if the direct feed from the battery is lost.
It is a little strange that power returns a few minutes later. Indicates that it may be heat related. Sometimes if a terminal is not tight enough it will heat up. As it gets hot it expands and may lose contact. Once it cools it it contracts and tightens on the contact again giving you power again.
Check the battery terminals are tight. Also check the earth terminals are all tight.
Hope that helps.
Hope that helps.
It will be the battery, a cell joiner has broken and is making contact intermittently. Starting current will weld the break temporarily and vibration will break it again, the car will be working on the alternator only. But check all wiring and terminals first. Measure the battery voltage on the terminals when the car is dead, (before it self heals)
Interesting, I have a new customer with the same problem,His car died in our car park after a 2 hour drive ,so the battery should had have plenty of charge,We put a jump pack on his car and it fired straight away.
I put my money on the ignition switch as well,
He has put a new battery in it and seems to go alright at the oment,starting wise.
I asked him to let me know if it does sort it or if the problem comes back,We seem to be having a run on these ignition switches at the moment,Better keep one aside for my own car
Users browsing this forum: Foplips00, Google [Bot] and 70 guests
