Tyres
Tyres
Have just fitted new set of Guardian 185/60/14 tyres but they seem noisier than the original fitted directional tyres. The dealer says the Guardians have a quiet tread pattern but I am looking for recommendations before returning to ask for a change of tyre. Only a tiki tourist who likes to drive it on sunny days but we do longish trips when the weather is right. Any suggestions
Don't all new tyres seem noisy because the thread is deeper than the set that was replaced?
Otherwise the rubber could be a harder compound than the set you replaced... I have no experience with Guardians as Im still on the blasted OEMs at the moment, but it's fun to have the car sideways once in a while in them
Never heard of those either. However, I can wholeheartedly recommend the TOYO T1R's. Best tyres I've ever had, wet or shine! Glenn has them too, and I think he's very happy with them
Quote from Toyo NZ:
Quote from Toyo NZ:
Proxes T1R
The Proxes T1R is Toyo’s new ultra-high performance passenger car tyre, superseding the Proxes T1S.
The Proxes T1R utilises a newly developed silica tread compound with a ultra-high molecular polymer that provides improved grip levels on wet & dry roads and improved wear resistance. The directional tread pattern of the Proxes T1R maintains the exceptional resistance to aquaplaning of the Proxes T1S, combined with a new rib / block tread shoulder arrangement that improves dry cornering grip and improves resistance to irregular wear and tear.
Nina
Tyres
NEW, NEW, NEW…… It’s rare to hear anyone say something bad about a new set of tyres even cheap ones (except for noise unless they are really crap, as new tyres will invariably stick much better then your old one’s as they are nice and new = softer.
The REAL DEAL is after a year or two and 30+% wear, and it’s then I want to ask, “are they still sticking in the wet?”
DRY, DRY, DRY….WET, WET, WET…. Also most people praise tyres for their holding yet never really drive a car to sliding in the wet anyway (I’m talking about 50km/hr type driving here on that tight little roundabout, not excessive speeds).
The tyres on my NA were about 2-3 yrs old (Federal I think) and are lethal in the wet, then about 6 months ago I met someone who had just put the same one’s on their car and were singing the praises about their wet handling (NEW, NEW, NEW…).
My NB came with some Kuhmo’s that are wow in the dry (as are most upper end tyres), but then let go on the slightly off camber roundabout down the road in the wet. They are about 2 years old with 50% wear.
I will be getting new tyres soon and I’m keen to hear from anyone with a few miles on their tyres who has given them that extra little push. I want to find some that have some sticky life in them, I don’t do high Km’s so I want stick not necessarily long tyre life…
[Posted via External Email]
Gazda in the white HOT Mazda
Tyres
When I was looking for a budget tyre for a Barina the Guardian was recommended. I would think that the manager has given some ill informed advice and maybe doesn't know the MX5's very well. The Firestone dealer would probably have Bridgestone tyres available. I previously had run the Bridgestone GIII's and found them to be a good tyre and they handled well on the driver training at Taupo a couple of years ago.
Tyres
Put on Bridgestone G111s 205 50 15 on my NB turbo before Taupo this year and am happy with them on track and road. Got them from Bruce Gemmel tyres in Glen Innes (Auck). He did a package, four tyres $170.00 each and set up wheel alignment to Flyingmiata track specs for $50. He loved doing the alignment as he reckoned the MX5 had more adjustment than Porche. Hold in the wet pretty well unles too ethusiastic on the loud pedal with the turbo kicking in. Good luck....
White Lightning
