Wheel spacers??
Wheel spacers??
Has anyone had experience of where to get 32 mm wheel spacers in NZ? I've been quoted NZ$110 postage from the UK!
Wheel spacers
Good point re: certification - I'll have to run that past the certifier I think.
32 mm is the standard size that goes on the Exocet (dot co dot nz) - improves the stance.
These go on with the standard MX5 alloys.
Cheers!
Cheers!
how about some of these
http://www.palmside.co.nz/product_pcid_15633.html
then you can use the wheels to get the offset rather than running some super large spacers
they can do between 15x6 and 15x9
you could even go for some 13x8/9s if you use 1.6 brakes
basicly a six inch rim with +11 offset will work you can work out the widths/offsets from there
even try http://www.palmside.co.nz/product_pcid_15633.html
hope this helps
hope this helps
You can't cert 32mm spacers. http://www.lvvta.org.nz/documents/stand ... _Tyres.pdf
Definately get some different wheels.
Wheel Offset
Thanks for the advice. I'll either go for a 20 mm spacer or look at some new wheels.
