Hi,
My 1989 MX5 has failed a warrant because one of it's headlights doesn't go on
low beam, but high beam is fine. Do I have to get a whole new headlight unit
or can the bulb just be replaced?
Penny
low beam headlight
low beam headlight
Hi they should be sealed unit so you have to replace the whole thing they
arent very expensive new or about $15 second hand.
low beam headlight
Hey Penny
As Baz said they are cheap, you can get a new one from Repco for probably
about $25 to $30. Teel them you want the "sealed beam". They are a common size
that fits many cars and should be in stock. Time to change one is 10mins. If
you are on the shore I can do it for you.
A thought. If you do any night driving on the open road, I would suggest this
is a good time to upgrade your lights. Many of us have changed them to what's
called semi-sealed. This costs about $105- all up and you get halogen bulbs
which are about 100% brighter. From Repco the semi sealed beams are (part No.
7019ss) $73.98 (a pair) and then you need to buy a pair of halogen bulbs for
$30 ish. Personally I hated the dim MX5 lights at night, and this is a must
really an awesome improvement, but if you don't do night driving much or wanna
save the $$$ go with option A and get the sealed beam.
Drop me an email if you're on the shore and I can help if
not I'm sure someone local will.
"PO1SON"
"PO1SON"
Users browsing this forum: No registered users and 44 guests
