Stud pattern
Stud pattern
I am knocking around the idea of changing my wheel stud pattern from 4 stud to 5 stud, most likely 5x114 as that seems the most common in 5 stud for the sizes that I am looking at.
This will open a whole new range of possibilities of wheel options to me.
Anyone know what is involved, how hard it is, and how much it might cost?
Try some reading
I want 5 studs!!! but How? [Archive] - MX-5 Miata Forum
forum.miata.net › ... › Tires & Wheels
Aug 13, 2006 - 16 posts - 15 authors
5 studs will give me more selection on wheels and etc. ... As long as the bolt circle you desire is not so large the hub can not accomadate it ...
Wheel Spacers [Archive] - MX-5 Miata Forum
15 Jul 2010
5 lug conversion [Archive] - MX-5 Miata Forum
100+ posts
13 Dec 2007
Why does the Miata only have 4-bolt wheels ...
10 Oct 2002
Hub-centric rims? [Archive] - MX-5 Miata Forum
1 Nov 2000
More results from forum.miata.net
5 lug miata - Miata Turbo Forum - Turbo Kitten is watching you ...
www.miataturbo.net › ... › Suspension, Brakes, Drivetrain
Oct 8, 2008 - 20 posts - 5 authors
Don't say it's because there are more 5 lug wheels on the market, .... and your rear hubs are 5 lug, and you want to make your fronts 5 lug too.
Replacing rear wheel studs, is it tough?
21 Aug 2010
Konig Feathers look bit to narrow - spacers, hubs, studs ...
19 Jul 2010
4x114.3 / 5x114.3 HUBs
11 Jun 2010
Where to buy extra long wheel studs?
8 Feb 2010
More results from www.miataturbo.net
5 Lug miata? - ClubRoadster.net
clubroadster.net/vb_forum/32-brakes.../43552-5-lug-miata.html
Mar 18, 2011 - 30 posts - 16 authors
So does anyone make 5 lug hubs or swaps for NA miata's? I know they make aftermarket 5 lug hubs for 240sx just seeing if anyone has heard ...
LocostUSA.com • View topic - Possible Miata 5 Lug Conversion ...
http://www.locostusa.com/forums/viewtop ... 9413‎
Jun 24, 2010 - 10 posts - 6 authors
After searching for months for a possible way to convert the miata hubs to 5 lug, i think i have a way to do it, relatively easily: 1. For rear hubs ...
All 4 hubs for a miata 5 lug ...
13 Jul 2011
miata spindles... hub to convert to ...
12 Jan 2009
More results from www.locostusa.com
15 Jul 2010
100+ posts
13 Dec 2007
10 Oct 2002
1 Nov 2000
21 Aug 2010
19 Jul 2010
11 Jun 2010
8 Feb 2010
13 Jul 2011
12 Jan 2009
Didn't bother reading the response above as there was a lot of information. Sorry if this is a repeat...
I do know that the rx7 things (very technical i know) can be used as the v6 miata on miata.net that featured a while back had them. As to how, not sure but it might be an avenue to look into
http://www.miata.net/news/v6.html this one
Anytime you want to pull it apart, just yell.2low2c wrote:not to sure on price , but with what they charged you for the rear hubs and axeles last time. having said that without pulling one side of the rear apart to see exactly how they did it could workout fesible, the fronts aren't that hard its just the rear
